January 10, 2004, 19:25 |
Multi-Airfoil simulation
Hi
I have some problems in deal with the stall in a multi airfoil simulation with STAR-CD. I have cells enough and I have used several different turbulence models as well as different conditions for turbulence at far field. Have anyone some experience with this subject? I get good results of CL versus alpha for all alpha range except near stall where the lift continues increasing. Thanks ze |
January 14, 2004, 16:39 |
Re: Multi-Airfoil simulation
Hi
As you will find if you read a few texts on RANS solvers and their application to Aerofoil flows, this Phenomena is very common. Basically the turbulence model has difficulty in predicting the point of seperation on the aerofoil. Have a read of Wilcox - Turbulence Modelling, this should explain to you exactly what is happening. Regards James |
Multi-element airfoil analysis | CFD Rookie | Main CFD Forum | 12 | November 17, 2016 06:07 |
multi-element airfoil | K Anandhanarayanan | Main CFD Forum | 1 | November 12, 2002 00:46 |
Looking for :Multi-element airfoil simulation | Larry | Main CFD Forum | 0 | February 8, 2001 10:14 |
Multi Element Airfoil | J.Dumas | Main CFD Forum | 2 | May 13, 2000 07:24 |
Multi-element Airfoil | Karthikeyan D | Main CFD Forum | 0 | October 7, 1999 04:19 |
