PUMP air into the container
Old   July 19, 2004, 05:33
Default PUMP air into the container
PIN TU
Hai everyone.. I really appreciate if anyone can help me on this matter. I tried to simulate the pressure testing. My case is sound like this. I have a container(close container with open at the top). I'll fill up that container with the varies pressure from the top and measure the pressure on the container surface.
what type of analysis is this??? transient or something?
May be you have an example similar to this case..
I really appreciate your help..
Thank you in advance...
PIN TU..
Old   July 21, 2004, 09:48
Default Re: PUMP air into the container
xhliu1
Set the container surface as a boundry,and moniting boundry behavior in output control/moniting engineering,and you can get it.
water temperature in heated container ali Main CFD Forum 3 July 23, 2007 11:54
Vertical Container Rashid CFX 3 January 8, 2007 22:07
Patching of sandbed for non-rectangular container Stella FLUENT 3 September 28, 2005 13:25
water flowing in a container GaryWang CFX 4 June 29, 2005 09:26
pressure distribution in a closed container prasanth FLUENT 3 December 21, 2003 07:21
