Compilation Error....
Old   September 11, 2004, 20:24
Default Compilation Error....
Arnab
Hello All,
I am trying to run tutorial 11 from star-CD version 3.2 . once I complete writing geometry and problem file, I save and quit and then from main terminal, i run star by writing star into it.
But i get this compilation error messages and I am not able to make them right. So can anyone of you help me with this problem.
The compilation error message and also the uparm.f file is below for your consideration.
Compilation Error message:
mesolv% star
PNP: Initialized [2004-09-11-19:07:59] Automatic Sequential Automatic Parallel analyzer.
PNP: Allocated "mesolv,1" resource (1 process).
PNP: Overload STAR master processor with external moving mesh code.
PNP: Assigned "mesolv,1" to STAR solver (1 process).
PNP: Assigned "mesolv,1" to external moving mesh code (1 process).
PNP: Analyzing User coding in "ufile" directory.
PNP: compiling /mnt/SUNWspro/bin/f90 -w -fast -xarch=v9a -c uparm.f -o sunos64_5.8-ultra2-f90_6.1-dso/uparm.o
PNP:
PNP: NDOM=0
PNP: ^
PNP: "uparm.f", Line = 12, Column = 6:
ERROR: The source line following an INCLUDE line must not be a continuation line.
PNP:
PNP: IF(ISTAT.EQ.1) NDOM=NDOM+1
PNP: ^
PNP: "uparm.f", Line = 23, Column = 7:
ERROR: Unexpected syntax: "EOS" was expected but found "F".
PNP:
PNP: I(0) = NDOM
PNP: ^
PNP: "uparm.f", Line = 26, Column = 5:
ERROR: The characters found in the label field are not valid.
PNP: ^
PNP: "uparm.f", Line = 26, Column = 7:
ERROR: Unexpected syntax: "EOS" was expected but found "0".
PNP:
PNP: NUP = 0
PNP: ^
PNP: "uparm.f", Line = 27, Column = 5:
PNP:
PNP: DO 20 IC=2473,3061,14
PNP: ^
PNP: "uparm.f", Line = 31, Column = 5:
PNP:
PNP: CALL LIVCLL(IC,STAT)
PNP: ^
PNP: "uparm.f", Line = 32, Column = 5:
PNP:
PNP: IF(ISTAT.EQ.1) NUP=NUP+1
PNP: ^
PNP: "uparm.f", Line = 33, Column = 5:
PNP:
PNP: 20 CONTINUE
PNP: ^
PNP: "uparm.f", Line = 34, Column = 3:
ERROR: A continuation line must not contain a label.
PNP:
PNP: I(1) = NUP
PNP: ^
PNP: "uparm.f", Line = 35, Column = 5:
PNP:
PNP: f90comp: 187 SOURCE LINES
PNP: f90comp: 10 ERRORS, 0 WARNINGS, 0 OTHER MESSAGES, 0 ANSI
PNP: ***ERROR*** Compilation error in user file "ufile/uparm.f".
PNP: ==> Please check the compilation error messages.
mesolv%
UPARM.f file::
SUBROUTINE UPARM(VCORN,A,I)
INCLUDE 'comdb.inc'
COMMON/USR001/INTFLG(100)
DIMENSION A(0:999),I(0:999)
DIMENSION VCORN(3,NDMAXU)
INCLUDE 'usrdat.inc'
NDOM=0
DO 10 IC=14,602,14
CISTAT= 0 => DELETED
CISTAT= -1 => MARKED FOR DELETION
CISTAT=- 2 => NO SUCH FLUID CELL (may BE SOLID, BAFFLE,SHELL ETC)
CISTAT= 1 => LIVE CELL
CALL LIVCLL(IC,ISTAT)
10 CONTINUE
I(0) = NDOM
NUP = 0
IF(ISTAT.EQ.1) NUP=NUP+1 20 CONTINUE
I(1) = NUP
A(0)=DT
RETURN
END
Old   September 12, 2004, 05:25
Default Re: Compilation Error....
Brian
In Fortran, you need six blank spaces at the beginning of each line. Several of your lines start in column 5 or 6 - fix that and try again.
Old   September 12, 2004, 13:05
Arnab
Hello Brain and Others,
Thanks for helping me out. I went according to your suggestion and got those errors knocked out but i have got these 5 other errors which I am not able to take care of. And that is why my program is not yet running.
Below is the new compilation error message:
mesolv% star
PNP: Initialized [2004-09-12-11:59:24] Automatic Sequential Automatic Parallel analyzer.
PNP:
PNP: DO 10 IC=14,602,14
PNP: ^
PNP: "uparm.f", Line = 14, Column = 8:
ERROR: A termination statement is missing for this DO statement.
PNP:
PNP: CISTAT= 0 => DELETED
PNP: ^
PNP: "uparm.f", Line = 16, Column = 18:
ERROR: Unexpected syntax: "operator or EOS" was expected but found "=".
PNP:
PNP: CISTAT= -1 => MARKED FOR
DELETION
PNP:
PNP: "uparm.f", Line = 17, Column = 19:
PNP:
PNP: CISTAT=- 2 => NO SUCH FLUID CELL (may BE SOLID, BAFFLE,SHELL ETC)
PNP: ^
PNP: "uparm.f", Line = 18, Column = 19:
PNP:
PNP: CISTAT= 1 => LIVE CELL
PNP: ^
PNP: "uparm.f", Line = 19, Column = 18:
PNP:
PNP: 10 CONTINUE
PNP: ^
PNP: "uparm.f", Line = 24, Column = 10:
ERROR: Labels must be in columns 1 through 5 in fixed source form.
PNP:
PNP: ^
PNP: "uparm.f", Line = 31, Column = 9:
PNP: ^
PNP: "uparm.f", Line = 31, Column = 15:
ERROR: This DO variable is already being used as the DO variable of an outer loop.
PNP:
PNP: 20 CONTINUE
PNP: ^
PNP: "uparm.f", Line = 34, Column = 8:
PNP:
PNP: f90comp: 9 ERRORS, 0 WARNINGS, 0 OTHER MESSAGES, 0 ANSI
mesolv%
I will be waiting for your suggestions and help and also from others if they have so that I can go ahead with my simulation.
Thanks in advance,
Arnab
Old   September 12, 2004, 14:49
Arnab
Hello Brian,
Thanks for your help. I have been able to fix the problem of compilation.
Will disturb u again if I need any help,
Thanks,
Arnab
Old   September 12, 2004, 15:54
Brian
The explanations in the errors are pretty clear. Glad you got it sorted.
udf compilation error sdp FLUENT 0 February 5, 2009 02:58
UDF compilation error Hari FLUENT 0 February 22, 2008 13:40
Compilation error skabilan OpenFOAM Installation 1 September 17, 2007 13:33
Compilation error CFX 11 Beth CFX 0 July 26, 2007 19:36
Compilation error Karthick FLUENT 5 April 16, 2004 13:36
