July 15, 2005, 09:14 |
call posdat.f at the end of the run
Hi everybody Does anyone know, if it is possible to call posdat.f user subroutine at the end of the run, and not at the beginning or at the end of each iteration/time step? The condition
if(ITER.EQ.ITERS+ITSTEP) doesn´t work when the calcualtion converges before the maximum iteration number reached, what acctually should be the case always. Thank you for your help. |
July 15, 2005, 13:15 |
Re: call posdat.f at the end of the run
If(level.eq.1) !At the begining of iteration if(level.eq.2) !At end of iteration
July 15, 2005, 16:24 |
Excuse me, if I hadn't explained it properly. I need to run posdat.f only at the end of the last iteration, and not at the end of each iteration. With Level=1 or Level=2 posdat.f would repeat the procedure e.g. 700 times, if it is needed 700 iterations to converge. Is my question better explained now?
CFL in posdat | hamodi | Siemens | 2 | August 6, 2007 02:27 |
POSDAT | Sheila | Siemens | 2 | February 8, 2006 11:08 |
call posdat.f at the end of the run | Murali | Siemens | 2 | October 16, 2005 12:02 |
posdat in HPC | Won-Geun Lee | Siemens | 0 | May 23, 2001 20:03 |
Posdat | Maria Carlsson | Siemens | 1 | April 30, 2001 10:29 |
