about ufile
Old   September 28, 2005, 05:02
Default about ufile
Bono
hello, every one! I am trying using ufile in the output part, but when I launch the calculation, there are always errors like these: PNP: **WARNING** The "parm.inc" include file is not required in the "ufile/posdat.f" user coding file. PNP: **WARNING** The "parm.inc" include file is not required in the "ufile/uasi.f" user coding file. PNP: ***ERROR*** Compilation error in user file "ufile/posdat.f". PNP: ==> Please check the compilation error messages. Is it that because I did not install fortran compiler on my pc or of other reasons? please help me. I run star in windows system, but when I use the same ufile in unix system it is allright. Can anyone give me some advice? thanks in advance!
Old   September 28, 2005, 07:01
Default Re: about ufile
Richard
Probably you have the statement "include 'parm.inc'" in your subroutine. From v3.2 onwards, you do not need this and the compilation will fail. I don't know why it would work on unix but not windows, unless you are using v3.15 on unix and v3.2x on windows.
Old   September 28, 2005, 21:42
Bono
Thanks Richard for your response. I am using STAR_CD 3.22 on windows. Another question, do I have to install fortran compiler on my PC? I think the STAR itself has the complier. When using FLUENT, I do not have to install C compiler at all, and the udf still works well.
Old   September 29, 2005, 03:35
Richard
No, you need a fortran compiler if you want to use user subroutines. Check which one you need - only certain ones are OK.
Old   October 3, 2005, 17:10
Jamie
The Absoft fortran compiler is needed only if you are using subroutines, so in this case you need it.
Old   November 2, 2005, 20:26
limingtiger
is compaq visual fortran 6 suitable for star-cd 3.15?
