parameters of turbulence models
Old   January 16, 2007, 02:53
Default parameters of turbulence models
george
Hello to everybody,
I use the standard k-e turbulence model and I want to see Reynolds Stresses. A partner from this forum tell me to set real constant 113 to 1 in PROSTAR and edit parm.inc to increase NSC parameter by 6 (six stresses) before running STAR, but the only thing I found is the file parm.inc and I found also the parameter NSC. Do someone know how can I set real constant 113 to 1 in PROSTAR? Is this an information in an ascii file or do I have to change something in the software of my computer? Thank you in advance.
George
Old   January 16, 2007, 05:14
Default Re: parameters of turbulence models
john
Sorry just returned: in PROSTAR, Analysis Controls=>Other Controls=>Switches and Real Constants
Select Real constants, set c113 to 1, and apply, write problem file.
Old   January 16, 2007, 09:00
george
Hi again,
I changed the C113 in 1,then I wrote problem file and in the parm.inc I changed the corig parameter:
CORIG PARAMETER (NSC = 6)
PARAMETER (NSC = 6)
and when I try to run it an error message displayed:
*** YOU ARE RUNNING DOUBLE PRECISION VERSION *** *** REYNOLDS STRESSES (MOLECULAR STRESSES NOT INCLUDED), -rho*uiuj, WRITTEN FOR POST-PROCESSING *** Read 1 tables in the problem file *** ERROR #225 *** NEED DEFINE 6 NON-SOLVED SCALARS TO STORE THE REYNOLDS STRESSES, WHICH ARE T11,T12,T13,T22,T23,T33 PNP: Shutdown [2007-01-16-16:03:57] Execution aborted by request (SIGABRT) after 3 seconds (TOTAL ELAPSED TIME).
Turbulence model parameters Vidya Raja FLUENT 2 October 6, 2006 13:38
Turbulence Parameters Bob FLUENT 0 July 28, 2004 15:32
turbulence parameters Lio Main CFD Forum 0 July 12, 2004 04:38
Turbulence parameters Mikael Ersson Main CFD Forum 0 May 13, 2004 21:28
How to set turbulence parameters at periodic BC? Ray FLUENT 2 July 28, 2000 04:15
