coupling solid and fluid cells??
Old   March 6, 2007, 21:40
Default coupling solid and fluid cells??
kcg
I`ev started using star cd recently,an anyone tell me how i can merge the solid and fluid cells.I tried using the 'assemble grids ' option but i get an error when i try to save the geom file.The error that I get is "Materisl assigned to solid is a fluid".
Any help is greatly appreciated.
KCG
P.S:I have a solid heat source inside a fluid.
Any suggestions??
Old   March 7, 2007, 05:26
Default Re: coupling solid and fluid cells??
allan
you need to have a different cell type for solid and fluid cells. In each cell type you specify the material number. You probably have the same material type assigned to both fluid and solid cells. Click the CTAB button in prostar
allan
Old   March 8, 2007, 09:01
sidd
What do you eaxctly mean by merging, creating couple? Its not possible to make a solid-fluid couple. For coupling master and slave both should be either solid or fluid.
But if you have same surface mesh at the solid-fluid interface, then you will have to merge the correspondng one-to-one vertices.
Old   March 10, 2007, 19:09
kcg
Can I create a fluid -fluid couple and create a boundary inbetween the cells??
Old   March 13, 2007, 09:39
KtoTo
Hi, you can read Tutorial 10 STAR-CD v.3.26 or like this (about buoyancy driven flow). Or you can modify all cells to one type, merge and than to modify some cells to needed type if mesh geometry allows this (this is done in this tutorial).
Fluid-solid coupling n.P=n.sigma? jinwon park Main CFD Forum 1 October 29, 2007 15:26
Shell cells to Fluid cells Mahbub Siemens 1 October 20, 2003 15:21
Fluid-structure coupling problem bluebird Main CFD Forum 4 January 25, 2003 10:04
Fluid-structure coupling problem bluebird Siemens 0 January 16, 2003 22:32
Fluid-magnetic coupling Leonardo Trindade Main CFD Forum 2 June 28, 1999 06:02
