what is zero face area failure??
Old   May 27, 2007, 01:23
Default what is zero face area failure??
DON
hi, could anybody explain what is zero face area failure in proam?why do we get this failure and how to rectify this problem??
thanks..
Old   May 31, 2007, 03:40
Default Re: what is zero face area failure??
DON
can anybody help???
Old   May 31, 2007, 05:51
xdm
NO!
Old   May 31, 2007, 14:07
Ben
remesh time....
Old   May 31, 2007, 15:14
paulh
Who knows why this happens â€" or better yet why it is allowed to happen. However, you have a couple of options.
Check to see that there is nothing in the surface and/or subsurface in the area of your bad cells that would cause a problem â€" spikes, overlaps, etc. â€" if there is, fix it. You can then remesh as usual.
Manual cell fixing â€" delete the bad cells, surrounding cells if needed, and click in some new cells by hand. Or you can just delete the bad cell and run the model with a cubic like obstruction. Make sure to check that the remaining CpMatches are valid.
There is no silver bullet.
Old   June 1, 2007, 01:09
DON
thanks Paulh , let me try...
Area of a particular face of the cell using UDF krish Fluent UDF and Scheme Programming 20 September 16, 2015 05:08
Face Area Corentin FLUENT 2 April 9, 2008 11:33
how to get cell face area in RADPRO.F cthsieh Siemens 1 January 2, 2007 08:53
Face area gg FLUENT 0 June 30, 2003 04:18
face area John FLUENT 1 August 13, 2002 04:12
