July 20, 2007, 00:06 |
Pressure Inlet BC in starccm+
How to give pressure Inlet BC in CCM+ as it have only Pressure outlet BC and not allowing inflow from this BC, if applied at Inlet. Can we specify only pressure BC in CCM+. My case involes atm. BC at inlet & outlets and having rotating fan inside the volume. Thanks in advance..
July 20, 2007, 01:51 |
Re: Pressure Inlet BC in starccm+
use the stagnation bc
July 25, 2007, 09:54 |
I've done similiar simulation using Pressure outlet at the inlet, it gave me reasonable data back, at least comparing with experiment, the only thing was ccm+ complaining about reversed flow in all inlet faces, but I do not know if it is correct to do it like this, it seems to work..
July 30, 2007, 16:53 |
I also use for inlet BC pressure outlet, and there was reversed flow and i get results what i need...
it seems to work.. |
August 3, 2007, 04:28 |
What about outlet BC. We have to prescribe at least one inlet and one outlet BC in fluid flow simulation. So if at domain inlet is forced pressure outlet BC what have to be forced at domain outlet?
Reagrds, pp |
velocity inlet vs pressure inlet | cheong | FLUENT | 6 | April 9, 2011 03:07 |
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet | gabriel | OpenFOAM Running, Solving & CFD | 16 | September 30, 2009 18:20 |
Pressure Inlet BC | Prasad | FLUENT | 3 | January 4, 2009 22:55 |
Pressure at Inlet | selim | Main CFD Forum | 1 | July 24, 2007 20:27 |
Pressure at Inlet | selim | CFX | 0 | July 19, 2007 12:49 |
