"exception : return code 139"
Old   January 8, 2008, 20:20
Default "exception : return code 139"
june
hello everyone! does anyone experienced this error? I use opensuse 10.3 and ccm+ 2.08.007, and setup ccm+ on csh.
and one more problem. with ccm+ on linux. there are java error like this "star/bin# ./starccm+ java: xcb_xlib.c:52: xcb_xlib_unlock: Assertion `c->xlib.lock' failed." this error solved with Sun's technical support pages. this solution is run this command "export LIBXCB_ALLOW_SLOPPY_LOCK=true" in the shell. but problem is this command run without error on bash but this command don't run on chs or tcsh. so I setup ccm+ on csh and run that "export LIBXCB_ALLOW_SLOPPY_LOCK=true" command on bash. and after open or create sim file, ccm+ show below exception message. so I checked the license server and it's status was good.
Exception error message\\\\\\\\\\\\\\\\\\\\\\ nnotation: Server process ended unexpectedly (return code 139). Server process ended unexpectedly (return code 139).
at star.base.neo.ServerConnection.connectToServer(Ser verConnection.java:467)
at star.base.neo.ServerConnection.startServer(ServerC onnection.java:339)
at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:108)
at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:93)
at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:183)
at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:170)
at star.coremodule.ui.OpenOptionsDialog$1.run(OpenOpt ionsDialog.java:83)
at org.openide.util.RequestProcessor$Task.run(Request Processor.java:499) [catch] at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:932)
return code 2 Kwang-su Kim CFX 5 April 21, 2011 18:03
Return Code 2 - CFX 11.0 AMD 64 Bayard Morales CFX 0 December 5, 2007 08:36
return code 127 Dave CFX 1 September 27, 2006 22:11
Return code 255 (CFX-5.7.1) Jesper CFX 4 May 23, 2005 08:03
Help me, return code 255 Valery CFX 1 November 15, 2004 08:14
