Problems deleting an XYZ table in CCM+
Old   April 3, 2008, 19:44
Default Problems deleting an XYZ table in CCM+
Nate
Every time I try to delete a certain table I get a parallel node synchronization error and cannot delete it.
If I try to boot in serial mode instead of parallel and delete it I get an error as follows:
Breif:
A java.lang.NullPointerException exception has occurred. Click Show Details or see the messages.log file located in your /emchome/natesal/.star-2.08.007/var/log folder.
detailed:
at star.base.neo.ClientServerObjectManager.changeObje ctsCommand(ClientServerObjectManager.java:273)
at star.base.neo.ClientServerObjectManager.remove(Cli entServerObjectManager.java:239)
at star.common.ui.TableNode.destroy(TableNode.java:85 )
at org.openide.explorer.ExplorerActionsImpl$DeleteAct ionPerformer.doDestroy(ExplorerActionsImpl.java:62 0)
at org.openide.explorer.ExplorerActionsImpl$DeleteAct ionPerformer.performAction(ExplorerActionsImpl.jav a:570)
at org.openide.explorer.ExplorerActionsImpl$DeleteAct ionPerformer.actionPerformed(ExplorerActionsImpl.j ava:631)
at org.openide.util.actions.CallbackSystemAction$Dele gateAction$1.run(CallbackSystemAction.java:559)
at org.netbeans.modules.openide.util.ActionsBridge$Ac tionRunnable.actionPerformed(ActionsBridge.java:87 )
at org.netbeans.core.ModuleActions.invokeAction(Modul eActions.java:80)
at org.netbeans.modules.openide.actions.ActionsBridge Impl.invokeAction(ActionsBridgeImpl.java:30)
at org.netbeans.modules.openide.util.ActionsBridge$Ac tionRunnable.doRun(ActionsBridge.java:78)
at org.netbeans.modules.openide.util.ActionsBridge$1. run(ActionsBridge.java:47)
at org.openide.util.RequestProcessor$Task.run(Request Processor.java:499) [catch] at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:932)
Anyone seen this problem before?
Old   April 4, 2008, 04:43
Default Re: Problems deleting an XYZ table in CCM+
Jim
Is the table being used somewhere, for a boundary condition or initialisation or on a graph etc? If so you will need to make sure that the table is de-selected before you can delete it.
Old   April 4, 2008, 12:17
Nate
It isn't being used anywhere.
Old   April 4, 2008, 15:15
Jim
Then try upgrading to the latest version, 2.08 is fairly old now, it might have been a but in that release
Old   April 7, 2008, 15:31
Nate
Our IT person just got a promotion and is no longer running the system. It'll probably be 2 weeks before the new person is up to speed and caught up on everything to do that for me. Doesn't matter though. I just reverted to an earlier version about 100 timesteps before that didn't have the tables implemented yet. Deleted all the derived parts and recreated them along with the tables and now it all works. I don't know what could have happened. It didn't seem like a corrupted file but who knows. Very bizarre problem.
DPM: using UDF for creating and deleting Particles Markus Alzon FLUENT 0 July 4, 2007 01:18
deleting internal wall HK CFX 1 March 16, 2007 08:54
Pro-Am deleting my Cell Table Ted Crilly Siemens 2 November 4, 2004 12:45
Deleting cell in a smart way Julie Polyakh Siemens 1 March 11, 2004 10:19
Deleting Edges in Gambit Alberto Schroth FLUENT 4 May 31, 2000 14:15
