Sphere in Cube
Old   April 11, 2008, 03:12
Default Sphere in Cube
sameer jaju
I am creating three dimensional cube with reactangular coordiate system and exactly at the center I want to creat sphere with spherical coordiate system. I can create them as and where I want but finally it given connectivity error, it shows some of the unconnected regions. Does anybody know about it. Thank you in advance.
Sameer
Old   April 12, 2008, 05:56
Default Re: Sphere in Cube
Joern Beilke
cdel all
vdel all
ctdel 4 20
ctab 2 flui 4
loca 10 sphere
! number of smoothing loops
*set smoo 5
csys 1
ctype 1
vc3d -1 1 20 -1 1 20 -1 1 20
cset all
cset subs gran -0.75 0.75 -0.75 0.75 -0.75 0.75
ctype 2
cmod cset
live surf create
cset news type 2
cdel cset
cset news type 4
vcex 5 ,, cset ,,, norm -0.05
cset all
live surf create
cset news type 1
vset news cset
cset add vset all
cset subs type 5
cdel cset
cset news type 5
vset news cset
vmod vset 0.5
*defi noexec
vset none
vell 20
vset news cset
vmod vset 0.5
*end
*loop 0 smoo
cset news flui
vset news surf
vell 200
cset subs gran -2 0.05
axis y
view 1 0.5 1
cplo
Old   April 12, 2008, 12:51
Sameer jaju
Dear Joern. Thanks a lot for your help. I do appreciate the time and consideration.
Old   April 12, 2008, 19:55
sameer
Dear Joern,
I experience little problem running this script. Can you please check the script again. I am very thankful for your kind help. I udestood most of the script. And finally it gives 'Connectivity' error. Thank you for your time and consideration. Regards,
Sameer
Old   April 13, 2008, 13:24
Joern Beilke
I moved the line "loca 10 sphere" to the top of the code. So coordinate system 10 was not active when it should be for the "vmod" command.
Just add a "csys 10" before the first "vmod vset 0.5"
Old   April 13, 2008, 23:23
sameer
Dear Joern,
Thanks a lot for your help. Can you please check the following command lines. I am creating solid sphere exactly at the center of the cube which is filled of the water. I have all the commands. i can successfully create the cube and sphere inside it. But it gives connectivity erroe and shows two groups of cells. Please run the following script
ctab 1 fluid 2
csys 1
ctype 1
vc3d -10 10 40 -10 10 40 -10 10 40
cset all
cplot
cset news gran -0.50 0.50 -0.50 0.50 -0.50 0.50
cplot
ctab,2,solid,3,,2
ctname,2,solid
cmod cset
cplot
crefine 5 5 5 cset 0 0 merg couple 1
cmod cset
cplot
cset news type 2
cplot
live surf create
cset news type 3
vcex 10,,cset,,,norm 0.05
cset news type 2
cplot
cset news type 3
cdel cset
cset news type 2
cplot
live surf create
cset news type 4
vset none
vell 15
loca 10 sphere
vset news cset
vmod vset 1
cset news type 2
vell 200
cplot
Can you please let me know how to remove this error of connectivity. And that will be all for my problem.
Thanks
Sameer.
Old   April 14, 2008, 05:50
Joern Beilke
Coupling between fluid and solid cells is not allowed.
Old   April 14, 2008, 12:45
Sameer jaju
Then what is the best idea to proceed further. How do I remove that connectivity error. I went through manual and applied all the possible commands like Vmerge and all but still it shows error in that. I am clueless at this point of time. Thanks
Sameer
Old   April 21, 2008, 14:55
Joern Beilke
Couples are not allowed between fluid and solid regions. So don't do the "crefine" for only the solid cells.
Run the macro without the crefine at all to see what you get and use some more cells for the initial block.
Old   April 24, 2008, 02:13
Joern Beilke
Cell are sometimes left-handed after a vcextrude command. Just open the check-tool and use the option "right-handed". Then click on "fix left-handed".
Here is the complete macro:
cdel all
vdel all
ctdel 4 20
ctab 2 flui 4
*set smoo 5
csys 1
ctype 1
cset all
ctype 2
cmod cset
live surf create
cset news type 2
cdel cset
cset news type 4
cset all
live surf create
cset news type 1
vset news cset
cset add vset all
cset subs type 5
cdel cset
cset news type 5
vset news cset
loca 10 sphere
csys 10
vmod vset 0.5
*defi noexec
vset none
vell 20
vset news cset
vmod vset 0.5
*end
*loop 0 smoo
cset news flui
vset news surf
vell 200
chec,all,0,righ,news,noli
cflip,cset
check,all
cset all
axis y
view 1 0.5 1
cplo
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Sphere in Cube Sameer jaju FLUENT 2 April 15, 2008 19:13
Which method is better for flow around a cube Alper Main CFD Forum 2 April 9, 2007 14:24
Cd of cube Naga FLUENT 1 November 25, 2004 14:33
Natural convection at a cube Michael Main CFD Forum 6 June 25, 1999 10:39
