Free Surface Calculation
Old   June 6, 2008, 00:34
Default Free Surface Calculation
Casey
In my simulation, I have gas being injected tangentially into a cylinder full of water and I want to observe the free surface after steady state is reached. I've used the "Free Surface" option in Pro-am, but the calculation either stops due to divergence or the end result doesn't look what I expect for steady state. Any suggestions on which settings to change to improve the Free Surface function? Thanks in advance.
Old   June 7, 2008, 04:59
Default Re: Free Surface Calculation
murash-v
It must be transient. Example like you (1636KB): http://www3.msiu.ru/~murash-v/widsh.avi
Old   June 7, 2008, 06:05
post-treatment question
Is the initial volume of gas conserved in this example?
It does not seem to be. This happens in comet as well, there is a loss.
Have you done a graph plot total mass of gas versus time?
Old   June 7, 2008, 06:28
murash-v
volume or mass? I have compressible gas
Old   June 8, 2008, 00:47
Casey
The volume of gas isn't conserved. I realized that I made a mistake in my original description. The cylinder is not completely full of water, but mostly (maybe 80%). There is an outlet that the two phase mixture can leave through.
Old   June 8, 2008, 10:17
Pauli
Grid refinement & time step.
Old   June 8, 2008, 12:21
Andrea
try also to use an UD scheme for the sim...you can restart later with a MARS scheme if you want to be correct with the results... And try also to initialize the sim via initfi.f, not by auto-initialization...if you can do that you'd probably get a more "stable" simulation
Old   June 13, 2008, 18:59
Casey
Thanks everyone.
Surface area of free surface jaswi OpenFOAM Post-Processing 0 July 25, 2007 14:34
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 14:43
[surface tension effect at free-surface ?] name Main CFD Forum 1 September 21, 2001 09:54
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
