(urgent)parallel analysis problems
Old   July 16, 2008, 01:23
Default (urgent)parallel analysis problems
Karteek
I have run the same moving mesh case on 10 processors and on 3 processors. The 10 processor case diverged while the 3 processor one it is still running. I am confused. Is it normal?
Old   July 18, 2008, 19:04
Default Re: (urgent)parallel analysis problems
underGroundMan
Karteek if you are running excatly the same case on 3 processors, it will eventually diverge. Hopefully, that would relieve you from your confusion.
Regards
Parallel computer system for FLUENT analysis Jane FLUENT 4 December 4, 2008 01:26
Convergence problems... need help urgent!! HSeldon FLUENT 1 March 15, 2007 01:04
Problem about multi-phase analysis (Urgent) Prof. Lau (PolyU) CFX 2 February 9, 2007 17:59
Urgent!! Problems in grids maoasis FLUENT 1 May 2, 2006 09:33
UDF in parallel analysis? Ricky FLUENT 0 May 5, 2003 04:44
