fluid pass through a filter(pressure drop setting)
Old   September 11, 2008, 19:55
Default fluid pass through a filter(pressure drop setting)
Jasica
how to model the fluid passing through a filter with pressure drop setting ?in my opinon porosity may be a choice. but definitions are too many(also have other tasks to do)!can I enter only a pressure drop to finish this task.Or finally the porosity is the only way.thank you.
Old   September 13, 2008, 09:42
Default Re: fluid pass through a filter(pressure drop sett
Julien
First you calculate the alpha and beta porsity coefficients with the pressure drop curve of your filter.
The quality of filter modelisation depends on the number of layers you use. I can suggest to use at least 3 or 4 layers.
Have a nice job
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 11:51
Problem to obtian pressure drop across bag filter Sanyo CFX 9 February 4, 2009 06:13
pressure drop jay Main CFD Forum 1 September 24, 2008 09:27
total pressure drop and momentum source setting Li CFX 2 July 28, 2008 02:33
Setting Roughness on a Solid-Fluid Interface JensonButton CFX 1 February 7, 2008 13:41
