Coordinate System Orientation
Like Tree3Likes
  • 1 Post By husker
  • 2 Post By ryancoe
Old   August 21, 2012, 17:14
Default Coordinate System Orientation
Ryan Coe
ryancoe is on a distinguished road
Does anyone know how to get the relative orientation of a local coordinate system in a field function?
I have an overset region in my simulation, which rotates at an arbitrary rate (will eventually be controlled by a macro). I'd like to get the orientation of that region directly (without integrating the rotation rate over time).
I thought I could use something with the $$Centroid or $$Position functions, possibly in conjunction with the cross product function, but just get zeros.
Any thoughts?
Thanks,
Ryan
Ryan
ryancoe is offline   Reply With Quote
Old   August 22, 2012, 06:04
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Have you tried to generate a new coordinat system, and then use that coordinate system in the field funtion?
siara817 is offline   Reply With Quote
Old   August 22, 2012, 07:59
Ryan Coe
Yes. I've created a local coordinate system that is "managed" by the rotation motion (it rotates according to that motion).
So I have a coordinate system that is rotated, and the lab coordinate system to which I would like to find its relative orientation, but haven't figured out a field function to do so.
Ryan
Ryan
Old   August 22, 2012, 08:15
husker is on a distinguished road
You can find the relation between user created coordinate system and lab coordinate system. You should open the edit menu of the coordinate system you created. Then you will find the center coordinates and the relative angles of it.
Regards
rschwab03 likes this.
husker is offline   Reply With Quote
Old   August 22, 2012, 08:28
Ryan Coe
Yes, I've noticed that. If I could only get those numbers into my field function, I'd be happy. Any ideas?
Thanks,
Ryan
Ryan
Old   August 28, 2012, 19:47
abdul099 is on a distinguished road
When you anyway do it with a macro, you can get the orientation from the coordinate system by the macro. Then you can either process it directly in the macro or the macro can put it in the field function.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   January 31, 2013, 16:17
Ryan Coe
I finally came back to this issue... As abdul points out, doing this in a macro is much easier.
angle = Vector3D.angle(rudderCsys.getBasis0().toDoubleArray(), bodyfixedCSys.getBasis0().toDoubleArray())
crevoise and CY80 like this.
Ryan
Old   November 4, 2014, 03:46
Bernardo Vieira
bvieira is on a distinguished road
Hi Ryan,
I see that you figured a way of extracting the orientation of the coordinate system within a macro (java file).
However, I need to calculate the orientation at every time step (or at every X time-steps) and then export these values on a table. My macros don't allow me to perform activities during run time, except if I define field functions and tables.
Any ideia on how to do define a field function that extract that orientation?
Thanks a lot.
bvieira is offline   Reply With Quote
coordinate system, field function, orientation, overset mesh
local coordinate system for porousZone Nico A. OpenFOAM Programming & Development 0 November 15, 2011 04:32
Creating Coordinate System ashtonJ CFX 0 February 17, 2011 21:07
Coordinate System selim CFX 1 October 26, 2007 21:08
On Coordinate system used in Fluent varghese FLUENT 9 March 22, 2002 11:16
Coordinate system Franch Siemens 2 March 6, 2002 07:56
