August 31, 2012, 06:14 |
6DOF moving F1 Wing
David
I'm trying to simulate the downforce of an f1 wing which is moving inside the fluid. I dont know how to set the wing motion, i've created a 6DOF Body and constraint its motion to the z Axis and as I dont know how to give it a certain motion I've tried to give it a force that produces that motion. Is there a easier way? I suppose so, thank you in advance.
pd: I've read the manual and specially the example of the boat but the boat moves becouse of the water and not becouse a fixed motion. |
September 5, 2012, 05:38 |
Henry Arrigo
I think you can use Mesh morphing or overset grid to give the wing a specific moyion.
September 5, 2012, 12:09 |
David
Very thank you. And how can i know if the movement is correct? how can i plot it? is there a report?
September 6, 2012, 00:59 |
Henry Arrigo
Use either max or min function to extract x/or y/or z_max/ or min point of the wing. then plot the position of this point.
September 6, 2012, 11:05 |
David
Very thank you mate. I will try it right now and give you news. Really, you helped me a lot.
September 6, 2012, 15:17 |
Rep Power: 21 |
Are you sure, you need a 6DOF motion?
Usually the motion is driven by the motion of the car, not by fluid forces, therefore I would just apply an inlet velocity and a moving ground boundary instead of using 6DOF (which is definitely the wrong model as soon as the wing can't move according to fluid forces).
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
September 6, 2012, 15:49 |
David
yes, you are right i handled to do it making some tricks but now i am trying to use the Morpher as Henry Arrigo said but I'm having problems becouse the wing does not follow the position i gave it, the amplitude is different, ideas? Thank you all.
pd: I dont know what you refer with moving ground boundary, as I know if i dont set the Morpher i only can give it velocity but not displacement. I will explain again what i want to do, i want to simulate a moving wing (with a prefixed movement) while it is in a moving fluid. |
September 8, 2012, 01:44 |
Henry Arrigo
I v had such a problem, unfortunately i could not find any answer. i think i this regard ansys-cfx works better. i d be glad if you can find a way to overcome this issue in ctar-ccm+, because i left my problem unsolved.
Here is the link of my discussion: http://www.cfd-online.com/Forums/sta...e-morpher.html |
September 8, 2012, 06:07 |
David
Finally It was solved by using the rigid body motion and gave to it a prefixed velocity, i'll take a look at the morpher and try to discover why but it is weird. Very thank you to all of you that helped in this topic.
[ICEM] Blocking For Swept Wing | air_engineer_arsenal | ANSYS Meshing & Geometry | 13 | July 24, 2012 11:52 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Flapping wing by moving frame | loogtaan | FLUENT | 1 | October 11, 2007 02:48 |
Segmentation Fault moving wing | lr103476 | OpenFOAM Running, Solving & CFD | 5 | May 4, 2006 06:51 |
External Aerodynamics - Moving Wing | Mick | FLUENT | 0 | October 3, 2005 08:13 |
