NEED HELP for position field function!!
Like Tree1Likes
  • 1 Post By abdul099
Old   October 24, 2012, 08:56
Exclamation NEED HELP for position field function!!
EnronZhang is on a distinguished road
Hey guys, I am currently working on a project about the oil spill tank. I am wondering if there is a field function which is relatively corresponding to the global coordinate?
That means, if I have known X and Y in the Cartesian coordinate, is it possible to create a field function to obtain the Z?
Thank you so much in advance!!
EnronZhang is offline   Reply With Quote
Old   October 24, 2012, 13:46
abdul099 is on a distinguished road
Maybe. What exactly do you want to achieve? How should your result look like?
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   October 24, 2012, 13:47
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
You can generate easily a field function by right clicking on Tools/ Field functions and select New. Then open the Definition node. But, how does Z variable depend on the value of X and Y theoretically? Do you have some equation that gives you the value of Z according to X and Y?
siara817 is offline   Reply With Quote
Old   October 25, 2012, 10:23
Hi siara, that's what I want to generate. For instance, I have a tank which is full of oil and water inside. It is two phase model. Of course, the oil is on top of the water as its light density. In this case, the top boundary surface is not flat, instead, it is inclined plane. I would like to create a field function to obtain all the Z values on this top surface to determine the the oil domain. Since the top surface of the tank is inclined, the oil thickness is variable. But I want to define the oil thickness to be constant in 2mm under the tank's top surface. How should I create this field function? Thank you for your help in advance.
Old   October 25, 2012, 10:24
Hi abdul, that's what I want to generate. For instance, I have a tank which is full of oil and water inside. It is two phase model. Of course, the oil is on top of the water as its light density. In this case, the top boundary surface is not flat, instead, it is inclined plane. I would like to create a field function to obtain all the Z values on this top surface to determine the the oil domain. Since the top surface of the tank is inclined, the oil thickness is variable. But I want to define the oil thickness to be constant in 2mm under the tank's top surface. How should I create this field function? Thank you for your help in advance.
Old   October 25, 2012, 14:17
siara817's Avatar
Ok, I assume that you know what is the equation for the surface according to the viscosity of surface. Then you can put X and Y to get the Z value.
You can show scalar variables by $ and vectors by $$. to find more about programming, search in the help "field function programming reference"
Old   October 26, 2012, 16:30
Do you want this to be an initial condition or a boundary condition?
When the top surface is just inclined but flat, I would create a coordinate system parallel to the plane. Than you can reference the Z-coordinate directly. Something like $$Position("Coordinate System 1")[2]. Not fully sure about the syntax, I don't have the user guide open right now, but I'm pretty sure you'll find it.
When the top surface is corrugated, it's much more complicated, so I'm too lazy to explain it when it's not necessary
amolrajan likes this.
coordinate, field function, position
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Position Field Function amish STAR-CCM+ 2 January 6, 2012 09:54
Field function cannot be evaluated on region pauloabeck STAR-CCM+ 2 April 28, 2011 18:40
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 03:45
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
