December 1, 2012, 16:09 |
Drag Coeffient monitor very high
anonymous
Rep Power: 13 |
I am modeling a NACA 0012 in 2D. I have drawn the aerofoil and the freestream box in NX and imported the CAD in. I then set everything up and I have set up two monitors for Cl and Cd in order to compare them to experimental data.
The Cl I have is around 1.2 which is a little high but the Cd i have is -3 and should be around 0.2. I have no idea why this is. I have set the reference values correctly I think in the monitor section (1.177 for density ref pressure is 101325 velocity is 6.943 force option is pressure +shear and the direction is set to components 0.9848,0.1736,0 as the aerofoil is simulated to be at 10 degrees. I have been looking for ages as to why the drag might be so high as I cant see anything wrong. any throughts? |
December 4, 2012, 21:14 |
John
Rep Power: 16 |
You should resolve forces in the streamwise(drag) and normal(lift) directions since your freestream is at an alpha.
December 21, 2012, 04:56 |
Niaz Ali Ahmed
Rep Power: 15 |
Hi try choosing Standard K-Epsilon Low Re with adequate mesh resolution near the wall...
coefficient, drag, monitor, naca 0012 |
drag coeff to high - kOmegaSST turbulence model | RugbyGandalf | OpenFOAM | 5 | February 22, 2011 02:35 |
high amount of drag coefficient. about 15????Is it okay? | ndabir | CFX | 3 | February 1, 2010 17:10 |
High drag coeff. estimated by Gambit+fluent | M. suuri | FLUENT | 6 | November 6, 2006 08:02 |
high drag value | sulfi | FLUENT | 1 | April 8, 2005 19:27 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
