Help with Field Function describing Force
Old   March 12, 2013, 03:25
Default Help with Field Function describing Force
VKS
VinayKS is on a distinguished road
I am attempting to model the motion of a vehicle that behaves as follows -- While above a certain Depth (say, 2.5m), there is a force acting downwards. And when it goes below 2.5m, the force begins to act upwards.
I have tried modeling this by using a field function for a Force acting on the CM of the object. However, I am getting the following error --
"Error: field function 'Simulation>BodyManager>Body("Body 1")>ExternalForceAndMomentManager>ExternalForceCM( "Force CM 1")>VectorPhysicalQuantity>InlineFieldFunction("In lineFieldFunction")' compilation error: syntax error
Cannot evaluate expression"
The expression I am using is
[50.0, ($$Centroid [1] > -2.5) ? -25.0, 0.0]
This is given in the DFBI --> 6-DOF Bodies --> External Forces and Moments --> <Name of Force> --> Force space.
Any idea why this is happening?
VinayKS is offline   Reply With Quote
Old   March 12, 2013, 03:27
VKS
Apologies - the expression I used was
[50.0, ($$Centroid [1] > -2.5) ? -25.0 : 25.0 , 0.0]
Old   March 12, 2013, 22:59
KHB
lava12005 is on a distinguished road
The centroid field function is used for getting the centroid of the mesh.
You need to refer to the centroid of the vehicle I believe.
lava12005 is offline   Reply With Quote
field function, marine vehicle, variable force
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
mean, variance and covariance statistics of any field function on any part. Subhadeep STAR-CCM+ 8 February 18, 2010 17:19
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
