Stagnation pressure
Old   March 23, 2013, 01:38
Default Stagnation pressure
Anonymous 92
jackwabbit is on a distinguished road
In my simulation of the flow around the Ahmed body to determine drag coefficient, at the front face, I am not getting the expected value of stagnation pressure. Any idea what could be the issue involved?
jackwabbit is offline   Reply With Quote
Old   March 23, 2013, 09:18
Vangelis Skaperdas
vangelis is on a distinguished road
what value do you get?
higher or lower than expected?
http://www.cfd-online.com/Forums/ope...-than-one.html
vangelis is offline   Reply With Quote
Old   March 23, 2013, 12:49
Anonymous 92
The pressure works out to be 1000 Pa higher than the expected value. What would you recommend for this case specifically since the Ahmed body analysis has been done over so many times. And yes, I'll read on that.
Old   March 26, 2013, 02:41
Vangelis Skaperdas
Try expressing this value as static pressure coefficient.
This value should equal 1 at stagnation point.
Old   March 26, 2013, 06:00
Anonymous 92
I did. But I got a value close to 2 where it was supposed to 1.
My physical conditions with respect to pressure are
Initial conditions
Pressure - 101325 Pa
Reference values
Force coefficient report
Reference pressure - 101325 Pa
My inlet and outlet conditions are Velocity Inlet and Flow split outlet, respectively.
I'm sorry but I'm still in the learning stages. Could you please help me out?
Old   March 26, 2013, 06:14
Vangelis Skaperdas
I am not familiar with StarCCM+ unfortunately.
My only guess would be to use another BC type for outlet
like Pressure Outlet instead of Flow Split
I am sure someone more familiar with Star can guide you
good luck
Vangelis
Old   March 26, 2013, 07:15
Anonymous 92
Ah, right. Still, thanks.
Old   March 27, 2013, 14:35
Ryne Whitehill
rwryne is on a distinguished road
Initial conditions
Reference values
Just to be clear, you realize that Initial Conditions and Boundary conditions use the reference pressure right? i.e. they are gauge pressures.
So when you set 101325 as your initial condition, you are setting the absolute pressure to 202650. Any pressure other than a "reference pressure" is understood to be <typed in value> + Reference Pressure
rwryne is offline   Reply With Quote
Old   March 30, 2013, 01:09
Anonymous 92
Oh, yes. Can't believe I missed that. Thanks! Changed, and it's fine, now.
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Stagnation pressure more than 1. hungpavn FLUENT 3 August 9, 2007 06:14
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
Fluent-V5,Turbomachinery (stagnation pressure live its own life) Alberto Tamm Main CFD Forum 19 May 27, 1999 14:42
