Shaft rotating in fluid CHT
Old   May 26, 2013, 18:16
Default Shaft rotating in fluid CHT
Jonny
Jonny6001 is on a distinguished road
I am looking at simulating a shaft rotating inside a cavity of air with the aim of monitoring the torque on the shaft due to viscosity. Added to this I would like to have the actual shaft solid part in the simulation so that I can see how the viscous heating affects the shaft temperature.
I have already ran the simulation with a "fluid only" domain whereby I specify the tangential velocity method on the surface that coincides with the rotating shaft surface. I have got good results using this method. I now want to include the solid shaft in the simulation. I have tried several methods but I always seem to get very low torque on the shaft compared to the tangential velocity method, they should be exactly the same.
I have the full fluid and solid regions and have defined an in-place contact interface where the shaft is in contact with the fluid. If I specify a tangential velocity for the contact interface between the fluid and solid I get zero torque on the interface. I have also tried to set the solid shaft region as a moving reference frame but get the same results.
It sounds like it should be a fairly simple method because essentially I have a shaft rotating in a fluid that I want to simulate.
Any help would be greatly appreciated.
Thanks
Jonny6001 is offline   Reply With Quote
VOF method- Fluid in a rotating Cylinder Problem Krishna Sandeep FLUENT 1 July 3, 2012 16:44
Please help me!!!!!!! analysis of a semi salvage rotating cylinder in a fluid adambarfi FLUENT 2 June 14, 2012 01:53
[GAMBIT] Rotating Cylinder Full of Fluid 1337Hal ANSYS Meshing & Geometry 4 April 7, 2009 03:38
CHT with radiation and body is rotating harish kumar CFX 0 February 1, 2008 12:00
Fluid in a rotating cylinder Fluid Novice Main CFD Forum 1 December 17, 1998 17:25
