Convergence of flow past finned body
Like Tree1Likes
  • 1 Post By SB123
Old   June 5, 2013, 12:23
Default Convergence of flow past finned body
SB123 is on a distinguished road
I'm running a 2D simulation of flow pass a finned body similar to the classic problem of flow past a cylinder. I'm working with Re #'s starting at 5. x10^5. When I work with a laminar model i get 'convergence' as my residuals are all below 0.01. but that doesn't seem right.
When I try a turbulent model (primarily working with k-omega, though I feel as though I've tried them all) the Tke and Sdr ends up on the order of 100 by the end of a 25 second simulation.which is at times taking me several days to run
I feel like I've looked everywhere for the issue:
-I've checked the 2D mesh for cell quality, skewness etc. and everything seems find there
-I've taken the time step down to as low as 1.0 x 10^-5
-The inner iterations up to 25
- I've tried lowering the under-relaxation factors for the k-omega turbulence solver to .2 and the k-omega turbulent viscosity to .2 the segregated velocity to 0.4 and pressure to 0.1
I can't seem to figure out what's going on and it's driving me nuts
are there any other thoughts or suggestions here?
SB123 is offline   Reply With Quote
Old   June 21, 2013, 11:41
eenee222 is on a distinguished road
I have a similar problem. It would be great if anyone can give recommendations!
eenee222 is offline   Reply With Quote
Old   June 22, 2013, 12:20
KHB
lava12005 is on a distinguished road
You should describe your simulation more I think.
Does the residual stay there or keep increasing?
What about other residual? Or maybe check something more physical such as drag coefficient, do they converge?
What about the boundary layer mesh? y+?
Any error during running such as limited turbulent viscosity ratio or any other error?
lava12005 is offline   Reply With Quote
Old   November 10, 2014, 17:44
the residuals hover around a significant value by the time i'm done with 3 different Re values. they are ramped to minimize 'shock' on the model over 0.5 seconds. drag coefficent has stabilized, lift coefficient has stabilized. i'm expecting lower values of drag than i am getting, what kind of cell count would be reasonable for a simulation like this. i've gotten as high as 500k cells. that seems a bit excessive, though when comparing monitored values like C_d and C_L_rms ans St they don't seem to agree, which would suggest increasing mesh resolution, but these are taking me some serious time to run, more than iwould expect, but i am new so what do i know!
as always help is much appreciated
Old   November 10, 2014, 17:47
and yes i am gettiing this error, i can't seem to get an answer as to what it signifies and how to address this issue. i had just increased the ratio limit... thoughts?
Old   December 13, 2014, 15:21
the problem with high residuals, i've been able to narrow down to need for more inner iterations per timestep (up to 50). this has since solved my problem. i hope this helps others in the future
bojueyang likes this.
convergence, turbulence analysis
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Modeling 3D external Flow over a streamlined body. gacins Siemens 4 January 22, 2012 05:46
Flow past a sphere Fabio FLUENT 23 December 18, 2009 15:32
Problem with Convergence at high flow rates Syed Siemens 1 April 10, 2007 15:18
2 Inlet Pres BC's and Out Mass Flow - Convergence SN Siemens 0 July 19, 2006 09:12
