Using Variables from multiple Physics Continua in Field Function |
October 30, 2013, 16:21 |
Chaotic Water
Rep Power: 17 |
Good day, enginners
If there are two Physics Continua (say, Water and Air) in my simulation - which are related to different Regions (so Continua/Variables are not coupled at all) - is there a way to use Variables (say, "Air.Velocity", "Air.Temperature" etc) from one Physics Continua in Field function that is used in another? For example - i would like to have something like this [written in pseudo-code]: $$Air.Velocity[0] < 300.0 ? $Water.Temperature*0.5 : pow($Water.Temperature, 2)*0.01 Any ideas? |
November 4, 2013, 09:55 |
Ryan Coe
Rep Power: 15 |
The only way that I know to do this is to use field functions to define the physics continua parameters. For example, you could create a field function named airVelocity
airVelocity = [1, 0, 0.1]then define physics continua with that field function. set initial velocity in Continua1 to '$$airVelocity'This way you can use airVelocity in other field functions and other continua. Hope this helps.
Ryan |
November 4, 2013, 10:17 |
Chaotic Water
Rep Power: 17 |
thanx a lot for your answer - but unfortunately that won't work in case that variable is not constant :<
November 4, 2013, 16:23 |
Ryan Coe
Rep Power: 15 |
The variable does not need to be constant. You can set the field function variable (airVelocity in my example above) dynamically (e.g., as a function of time or any monitor value that you like).
Am I not understanding your problem correctly?
Ryan |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
User field function for specific heat deifnition | crevoise | STAR-CCM+ | 2 | January 28, 2013 04:25 |
Multiple Physics Continua | boathead | STAR-CCM+ | 6 | December 4, 2011 12:33 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
