Richard Martinez
Rep Power: 0 ![]() |
Hello, I want to say sorry in advanced for my first post being a question, but it seems that I have hit a roadblock that I can't overcome by myself. My problem is as follows, I am trying to model a liquid going through a solid with these specific properties.
The solid properties are: Density: 1160 kg/m3 Poisson's Ratio: .5 Youngs Modulus: .2 MPa The liquid properties are thous given by default, H2O in this case. Setting and Physics: Tools • Motions- Right-click to create “New”- “Morphing” • Motions- Right-click to create “New”- “Solid Displacement” Continua • Mesh 1- Check “Per-Region Meshing” • Physics 1 (liquid)- Models o Constant Density o Gradients o Implicit Unsteady o Laminar o Liquid Set characteristics of blood o Segregated Flow o Three Dimensional • Physics 2 (solid)- Models o Constant Density o Gradients o Implicit Unsteady o Linear Isotropic Elastic o Solid Set characteristics of Solid o Solid Stress o Three Dimensional Regions • Be sure that the interface is set for all boundaries from solid to liquid • Regions- Inner_Part_Indentations- Properties Window o Set Physics Continuum to “Physics 1” • Regions- Inner_Part_Indentations- Physics Values o Motion Specification- Set Motion to “Morphing” • Regions- Shell_Part_Indentations- Physics Values o Motion Specification- Set Motion to “Solid Displacement” Stopping Criteria • Maximum Inner Iterations- 20 • Maximum Physical Time- 1 sec • Maximum Steps- 20021 My problem stems from the fact that I can run this with no problem when my solid properties are of those of any metal or even the rubber material found within the program. I believe the young modulus is set very low for this specific analysis. If anyone has some hints, solutions, theories or background information I would really appreciate it. I appreciate your time in advance. I forgot to mention I am trying to model displacement of my solid cylinder. My cylinder has a radius of 4mm for the fluid region and 4.8mm for the shell region. Thanks again, Richard |
Rep Power: 24 ![]() |
Are the displacements you expect still in the linear elastic region of the solid? Otherwise the FVS model should not be used.
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
