Max and min wave height variating in time with 5order stokes waves
Old   October 22, 2014, 03:20
Default Max and min wave height variating in time with 5order stokes waves
lucaoggi
lucaoggi is on a distinguished road
Hi everybody, I am currently running a simulation of a floating body in 5order stokes waves (1.8s period, 0.3m hight, 10mdepth).
What happens is that max and min wave height oscillates with a low frequency (ca.0.2Hz) resulting in large oscillations (on the same frequency) in the heave response whcih are summing to the supposed heave response due to the wave height/period. I have created my mesh following the suggestions that i found on the Steve forum and refining the free surface area as follow:
X & Y sizes to about 1/80th to 1/100th of the VOF wave wavelength.
Z size to about 1/20th of the wave amplitude.
second order unsteady solver time step relatively to the wavelength division chosen, using the following equation: if the dx chosen was 1/80th, then use (wave period) / (2.4 * 80).
The boundary conditions chosen are
velocity inlet for top, inlet and bottom
pressure outlet for outlet
symmetry for sides
I am having a long domain enough domain to damp my waves and i applied the damping to the pressure outlet boundary My model is 0.25m in diameter and i have and my domain size is 33m (from -8m to +25m)m, 10m, 20m. The model is placed 8m after the inlet.
Any clue about why this is happening?
Thanks in advance!
lucaoggi is offline   Reply With Quote
Old   October 31, 2014, 07:16
David
dai549592484 is on a distinguished road
give your result plot plz.
dai549592484 is offline   Reply With Quote
oscillating free surface, vof waves
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 05:06
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
