Unrealistic Temperature Gradients after refining mesh in some parts
Old   December 16, 2014, 08:28
Default Unrealistic Temperature Gradients after refining mesh in some parts
skapetan is on a distinguished road
I want to keep it short and describe my problem.
I generated a 2D Mesh for ribbed channel where I want to analyse conjugate Heat Transfer and validate experimental Nusselt data.
Some key facts from my analysis:
K-omega SST turbulence model, Contact-IF between Solid(Rib) and Fluid, AllY+-Treatment, WallY+ 0-13 ,Air enters the channel with an Temperatur of 293,15K, I set a constant heat flux of 200 W/m² for the channel bottom and rib bottom .
The channel consists of 12 ribs. The flow can be assumed as periodic. Therefore I evaluated just the Nu-Distribution between rib 9 and 10.
I've generated a grid which had a really good accurancy but I couldn't get satisfactory results for the validation.
Based on that I decided to refine the mesh from rib 9 to rib 10 and the walls were Heat is transfered. After refining I got a Wall Y+ values of <1 ( just for the near wall area from rib 9 to 10, rest of the channel remained between 0-13)
I expected to get better results (means more equal to the experimental data as before) in the refined area.
However I got unrealistic temperature gradients in the refined area of the solid and bad accurancy.
Can someone describe why the solution is that bad ?
I put some pictures in the attachment for better illustration.
I hope this helps.Thank you.
skapetan is offline   Reply With Quote
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
icem hexa mesh parts pb jaber Main CFD Forum 2 July 7, 2009 15:30
icem hexa mesh parts pb jaber FLUENT 0 June 12, 2009 18:06
