having trouble modelling basic convergent water nozzle flow |
January 31, 2015, 15:59 |
Olli
Not sure if this is the right place to ask but will explain my issues in case it can be passed onto someone that can help. I am trying to model a basic convergent water rocket nozzle, however my simulation results are very poor in comparison to manual calculations. I have created what I believe to be a working mesh and have set the inlet and outlet to be outlet pressure points. I have set the inlet pressure to be 20 bar and the outlet to atmospheric. Is this right? The inlet pressure will decrease with time, however I am unsure how to do this. Other things I require are the fluid velocity, thrust/ mass flow rate (which can then be used to calculate force?), the pressure and discharge coefficient. I am quite new to Star so apologies if this seems trivial. Thanks, Olli |
January 14, 2016, 16:37 |
I'd just replace the inlet with a mass-flow inlet, and monitor the pressure at the inlet, and then increase/decrease mass-flow rate until desired inlet pressure is achieved.
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 09:36 |
Two-phase critical flow and shock modelling of nozzle | Jeggi | STAR-CCM+ | 0 | December 4, 2014 09:12 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
