Duplicate scene in multiple simulation cases
Old   August 5, 2015, 00:41
Default Duplicate scene in multiple simulation cases
John Bulzacchelli
JohnnyOnTheSpot is on a distinguished road
I am wondering if there is a way to automate scene creation between multiple simulations.
In my case, I have multiple simulations of the same assembly, just with one component's position slightly changed. I would like to be able to set up my scene in one simulation, and apply it to all cases to speed up my post-processing time.
Thanks,
John
JohnnyOnTheSpot is offline   Reply With Quote
Old   August 5, 2015, 02:28
Swempa's Avatar
Swempa is on a distinguished road
Hi John,
You should be able to this if the naming is the same for the ingoing parts in the scene (parts, regions, derived parts etc..), if you have both cases opened at the same time, you should be able to just copy and past the scene into the other simulation case. Hope that this works for you!
Swempa is offline   Reply With Quote
Old   August 6, 2015, 22:10
John Bulzacchelli
Originally Posted by Swempa View Post
Hi John,
Oh wow... I wish I knew I could do that earlier.
You've saved me hours of tedious work!
Old   August 10, 2015, 14:49
Matt
fluid23 is on a distinguished road
FYI: You can copy just about everything that way. Not just scenes.
Also, a more direct and editable approach would be to use macros. Simply record the creation of one, then run the macro in the rest. Easy as pi.
fluid23 is offline   Reply With Quote
plot, post-processing, scene
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Use homogeneous results as the initial guess for an inhomogeneous simulation JuPa CFX 5 December 26, 2014 13:44
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 03:16
Blunt body aerodynamics simulation cases needed David FLUENT 0 June 1, 2003 11:40
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
