outlet boundary
Old   July 25, 2015, 06:38
Default outlet boundary
protocol is on a distinguished road
i have an subsonic flow in the outlet i want to find the value of pressure at the exit in star ccm manual its given that for subsonic flow pressure at outlet must be specified is it ok to target mass flow option and give inlet mass flow at outlet will this help me in finding out the pressure at exit boundary
protocol is offline   Reply With Quote
Old   July 28, 2015, 11:27
Matt
fluid23 is on a distinguished road
that is what I would do.
the mass flow inlet varies its pressure/velocity distribution to acheive the required flow rate. you will probably want a mass flow averaged report of pressure on the inlet. Do not create a report for mass flow at the inlet, however. It will pretty much always read what you input. Instead create a derived part a few diameters upstream and measure mass flow there. It will be give a better indication of performance.
also, I will mention... don't put 2 mass flow inlets. one pulling the flow downstream is enough. your upstream boundary should be a stagnation inlet or something like that.
fluid23 is offline   Reply With Quote
Old   July 29, 2015, 11:39
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hi
I don't think making the outlet boundary as inlet will give you a correct value of pressure. Even if you switch the inlet and outlet boundaries, the pressure values will not represent what one may get in testing with original boundary condition (which is very obvious)
As far as my experience is concerned, CCM+ gives fairly good result of pressure values at interfaces and boundaries. you can create extrusion layers of mesh (say 100 mm , 50 layers) if the expansion to atmosphere (0.0 static pressure) is resulting in erroneous values. This is what we usually do for our simulations.
ggulgulia is offline   Reply With Quote
Outlet boundary condition for wave flume with interFoam solver Arnoldinho OpenFOAM 9 July 10, 2018 05:15
pressure outlet boundary condition hamid_reza Fluent Multiphase 1 September 9, 2014 13:43
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Combining BCs: wall - outlet. Boundary layer disappears MartinaF OpenFOAM Running, Solving & CFD 1 July 20, 2009 18:14
