August 17, 2015, 23:21 |
Particle concentration
JungHo Lee
Rep Power: 11 |
Hi, guys.
Now, I have simulated the indoor room. Particles are injected in the room. Now, I want to know how to get a Particle concentration at any point. Finally, I will compared a particle concentration at each point in experiment and simulation for simulation validation. Is there any way to know the particle concentration at the point? |
May 23, 2016, 03:48 |
#2 | |
Ping Chang
Rep Power: 10 |
Have you found the solution for ur question? I met the same question. |
May 23, 2016, 05:48 |
kevin alun
Rep Power: 14 |
In derived part you can create a probe, point (give the x,y,z position)
create a maximum report using the part (you just created, point probe) and scalar is volume fraction of...(name you gave) Might want to check the smooth box in the report, it will interpolate to that position instead of a cell-center value, Sometimes it might be better to use a part of your volume mesh, create a threshold and use volume average report, this way if there is some uncertainty into what position your probe is, you are getting an average value, |
May 23, 2016, 08:14 |
#4 | |
Ping Chang
Rep Power: 10 |
I am really appreciate. |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 13:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
How to calculate the particle concentration? | Ken | Siemens | 1 | April 19, 2007 12:10 |
particle number concentration in a volume | DH | FLUENT | 0 | March 2, 2007 14:56 |
