Invalid License Server error
Old   August 26, 2015, 14:41
Default Invalid License Server error
FFD
FFD is on a distinguished road
I have a problem with running and installing Starccm+ (on Linux)
While Installation StarCCM+ 09.04 shows an error:
Invalid license server.
Invalid license server 1999@flex.cd-adapco.com no CDLMD vendor daemon found.
(some temp files)
/opt/CD-adapco/FLEXIm/11_9_1_0/bin/lmutil:not found
I press ok and Starccm continues installing.
Later when I want to start a new simulation or load a simulation Starccm shows the error:
ssh: connect to host 127.0.1.1 port 22: Connection refused
mpirun: Warning one or more remote shell commands exited with non-zero status, which may indicate a remote access problem.
The ports 1999 and 2099 are open. I seems to be a problem with ssh.
What can I do?
-FFD
FFD is offline   Reply With Quote
Old   August 27, 2015, 11:08
Lane Carasik
lcarasik is on a distinguished road
(some temp files)
What can I do?
-FFD
Where are you running your license server? Locally? Or on another computer?
lcarasik is offline   Reply With Quote
Old   August 27, 2015, 11:34
FFD
I use the PoD main Server from CD-Adapco.
I just clicked on set up for PoD while installation. and did an express installation. So he use the main server. And he do have a problem while installation. with the license server
Old   August 27, 2015, 17:40
Lane Carasik
It sounds like an issue where you're not correctly connected to their server. I would check to see if there are any similar issues on the Steve portal or open up a case to get it resolved.
invalid license server, mpi, ssh, starccm
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
