September 20, 2015, 06:34 |
Fan curve table
thomas
Rep Power: 10 |
I am doing aeroacoustic simulation on a fan in a cylinder domain. I use "in-place" interfaces and "fan interfaces" as type in the properties windows. In physics conditions, I setted fan curve as "Table" and then I need to input the table in the physic values. The problem is I don't know how could I get this table ?? If someone knows something about this, please I would appreciate some help. Thank you. |
September 21, 2015, 09:18 |
Matt
Typically when someone elects to use the fan interface or the fan source you are trying to approximate the behavior of a fan with known performance. Either that or you have some idea of the delta P and swirl characteristics you want to duplicate.
Are you trying to examine the aeroacoustic properties of the fan itself? If so, the interface/source approach is wholly inappropriate. You should be modeling the fan and using rigid body motion and modeling the blades of the fan rather than approximating their effect. |
September 22, 2015, 01:56 |
#3 | |
thomas
Rep Power: 10 |
maybe it comes from my under relaxation factor values for velocity and pressure, I really do not know ... by the way thank you for your quick answer |
September 22, 2015, 08:47 |
Matt
Try using a coupled solver if the segregated approach is failing. Its a better method for this anyway.
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Fan Curve Model with CHT simulation | mariconeagles96 | CFX | 5 | April 22, 2015 01:31 |
Considering the operating point instead of the fan curve | saisanthoshm88 | CFX | 8 | August 9, 2012 06:57 |
Propeller Fan Curve Simulation | Teng_YJ | FLUENT | 2 | February 16, 2009 19:37 |
