Computing Center of Pressure
Old   October 5, 2015, 10:53
Default Computing Center of Pressure
FFD
FFD is on a distinguished road
I want to compute the center of pressure. My thoughts were to find a point were all moments are 0. But i don't know how to find it.
The steve portal have an article about how to find the cop. But I don't really understand the idea behind that method and it doesn't really work. The cop is wrong for sure. I tried it on a simple airfoil and the line_point (described in the Steve Portal) didn't even hit the airfoil. But the CoP should be on the airfoil.
Have you any suggestions?
Regards
-FFD
FFD is offline   Reply With Quote
Old   October 5, 2015, 20:21
me3840 is on a distinguished road
There are many unique solutions to the CoP in 3D of a body. You must guess where the point is first, and then iterate the position of that point until all moments are zero.
me3840 is offline   Reply With Quote
Old   October 6, 2015, 03:29
FFD
I had the same idea. But how I can do itin Star-CCM? I am not really experienced in CFD. I had this idea:
I made a Force and a moment report for every axis.
But these vectors are for the full part. How can I check the force and the moment at a specific point? And How I can iterate the position? My idea would be to run the simulation and create a macro that change the values and check if the moment are 0 at that point. But that would be extremly inefficient.
But if I know how to check the moment at a specific point. Somebody do have any suggestions?
-FFD
Old   October 6, 2015, 19:28
The moment/force reports takes as input a coordinate system and direction, so you just pick a point and run the report.
You will have to write a macro to iterate through the positions, yes. It probably won't be as inefficient as you think.
Old   October 6, 2015, 19:29
This thread may help:
http://www.cfd-online.com/Forums/ope...aero-body.html
center of pressure, cop
Center of Pressure Value ENGRTAHIR CFX 2 October 7, 2014 09:51
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
How to find center of pressure cfdnewbie1 STAR-CCM+ 3 February 16, 2011 09:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
