October 29, 2015, 02:51 |
Automatical change of the angle of attack
Jon Ayerdi
I´m interested in getting different results of a profile working at different angels of attack (2D). To do this I´ve created another coordinate system (the one that says which one is the fluid direction, velocity...) and I rotate it in each simulation 5º.
It is possible to change this automatically? I mean, when the simulation arrives for example to 4k steps, the simulation by its own it is going to rotate the coordinate system and start it again (saving the previous results of course). Thanks! |
October 30, 2015, 08:53 |
Pablo Mtz. Filgueira
Rep Power: 12 |
I would like to know the same thing as I want to create polar plots of diferent airfoils to use them with BEM.
Hope someone can help us |
October 31, 2015, 02:01 |
kris
Rep Power: 12 |
Well... you could use a field function to define you velocity direction as a function of iterations and use auto save to save your sim file...
Or you could use a java macro to do that for you.... Hope this helps!! |
November 2, 2015, 16:15 |
Paul Hancock
When I want to simulate different angles of attack for my external aero analyses, I change my "Flow Direction Specification" to "angles" and then change the "Rotation Convention" to "Yaw, Pitch, Roll". I then update the angle. Once you figure out how to do it, java it.
angle of attack, automatic |
BCs for flat plate at angle of attack | Obad | Main CFD Forum | 1 | May 20, 2015 04:29 |
how to change angle of attack of a rotating blade in frozen rotor | momo_sjx | CFX | 0 | January 26, 2013 10:53 |
Suggestions required for modelling vortex generator with variable angle of attack | Crank-Shaft | ANSYS | 1 | January 4, 2013 22:31 |
not convergence in high angle of attack in low reynold number | nuimlabib | Main CFD Forum | 1 | October 2, 2009 14:10 |
Plotting of lift coefficient vs angle of attack?? | John | Main CFD Forum | 1 | August 18, 2003 09:31 |
