Geometry size problem
Old   April 27, 2016, 03:57
Default Geometry size problem
Fulvio
ThatGuy is on a distinguished road
Hi all,
I've been trying to run some simulations on a full-scale geometry which is about 20mx10m with some things inside. The models I chose are steady, ideal gas, coupled flow, gravity, turbulent (k-epsilon), axisimmetric. The kind of sim I'm trying to run is a 2D natural convection with a volumetric heat source with gravity vector pointing towards -x.
If I try with this model, either I get some error of overfloat, or it simply diverges. If I try the same with a really downscaled geometry, everything works fine.
I thought it could be a mesh problem, but all me attempts failed as well.
Any ideas?
Since I have to study some heat transfer, I'd like to avoid any reynolds similarity etc, since I'm not very used to that kind of thing.
ThatGuy is offline   Reply With Quote
[ANSYS Meshing] Problem in geometry meshing Itachi11 ANSYS Meshing & Geometry 3 March 15, 2016 14:38
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same kanes OpenFOAM Meshing & Mesh Conversion 0 January 25, 2016 08:06
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 22:15
[ICEM] Meshing Size Problem eRzBeNgEl ANSYS Meshing & Geometry 2 April 17, 2011 15:53
