Mesh adaptation methodology (capturing the shock)
Old   April 22, 2016, 02:48
Default Mesh adaptation methodology (capturing the shock)
taillanm is on a distinguished road
Hello!
I am modeling a case of a sphere-cylinder body (like a bullet) (2D axissymmetric). My ultimate goal is to make studies about transition.
My case: Mach of 1.5, coupled flow, free stream inlet, pressure outlet. I have no problems about the physics (as I refined manually along the shock with volumetric controls and ran the case, no problems... very time consuming to make manual mesh controls for the shock)
I followed step by step the methodology to adapt (refine) my mesh ("automatically") near the shockwave in front of my body, from this tutorial: https://steve.cd-adapco.com/articles...pturing-shocks
But I didnt succeed..
My mesh settings: polygonal + prism layers (20, at 1e-6 first cell, 3mm thick) I am working with absolute values for mesh sizes. Default: Target surface size: 0.01m Minimum surface size: 1e-5m Surface growth rate: 1.2 I have one volumetric control to refine around my body (5e-3m).
My field functions:
0-CellWidth : pow(${Volume}, 1/3)
0-DenGrad : mag(grad(${Density}))*CellWidth
0-Refine : (${WallDistance} < 0.04) ? 0 : (${Dengrad} > 0.05) ? ${CellWidth}/2 : 0)
The condition of wall distance is there because density gradients are also present near the boundary layer and I don't need refinement there..
I checked while the simulation is running, the cells supposed to be divided by two in length are highlighted, but when I remesh (after extracting my table), the refinement doesn't appear..
Am I wrong somewhere.. ?
taillanm is offline   Reply With Quote
Old   May 3, 2016, 05:56
the field function for the cell width is not valid, it should ressemble
some constant * pow(Volume/Position[1], (1/2))
but the problem still persists
field function refinement, mesh adaptation, shock
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Shock capturing in 2D/3D Abhishekd18 Main CFD Forum 2 June 27, 2014 11:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
