Solid Temperature in porous Media
Old   May 2, 2016, 12:55
Default Solid Temperature in porous Media
Sarthak Nag
iamsarthaknag is on a distinguished road
I am working on a simulation which consists of hot air flowing through a porous solid. I need to find the transient temperature of the porous solid. However, the porous medium option only shows up when I select gas physics model for the region (the porous option disappears if solid physics model is selected). The temperature scene that is available only seems to show the temperature of the air (or average of the solid+air ?).
Is there a way to find the temperature of only solid part in Star CCM+?
iamsarthaknag is offline   Reply With Quote
Old   May 23, 2016, 07:14
kevin alun
marmot is on a distinguished road
This is an old post perhaps you figured something out by now, if you use only 1 region you will only get an average temperature, you set the porosity value (fluid/total) and you give the solid properties but you will only see one temperature.
Perhaps you can read about heat exchanger models, dual stream, there is some idea with fluid/solid heat exchanger or having 2 regions, 2 physics continuum and exchanging heat with a volume heat source,
marmot is offline   Reply With Quote
porous media flow
porous media combustion zuby FLUENT 2 August 31, 2015 04:42
Scalar temperature transport in porous media unbounded at sharp transitions jameswilson620 Main CFD Forum 0 March 31, 2015 17:59
combustion in porous media burner zuby ANSYS 0 July 27, 2009 02:26
Porous Media as solid object Tom FLUENT 4 April 11, 2005 07:52
temperature distribution in porous media Alexey Siemens 1 June 23, 2003 01:11
