Modeling a filter bag (porous media) while having a compressible flow
Old   May 11, 2016, 16:09
Question Modeling a filter bag (porous media) while having a compressible flow
CFDFAN
SFRazavi is on a distinguished road
Good day,
I am trying to model a filter bag as a porous media while having a compressible flow.
I couldn't find related information in steve portal. There is just info about modeling porous media having incompressible flow.
Could you please guide me in this regard?
I appreciate your time.
SFRazavi is offline   Reply With Quote
Old   May 12, 2016, 12:41
Matt
fluid23 is on a distinguished road
I assume you have pressure drop data that you are using to calculate your resistance coefficients, no? Does this data span the full velocity range your media will see? If so, then your coefficients derived from this data will take into account the compressibility already. If not, then you may have to make some assumptions.
For example, if you have velocity vs dp data that is assumed to be incompressible you can go through and apply the Prandtl-Glauert correction to the pressure values before obtaining your coefficients (assuming you have subsonic flow). If you aren't going to see compressible mach number (above 0.3) then I wouldn't worry too much about it. Beyond M=0.3 you will start to see more than 5% impact and you might want to consider it, but below that it's fairly trivial and can be neglected.
fluid23 is offline   Reply With Quote
Old   May 16, 2016, 14:04
CFDFAN
Thank you very much for your prompt reply. It helps me ...
A solver for two-phase flow with a porous media enoch OpenFOAM Programming & Development 6 October 10, 2022 09:11
Flow through porous media: permeability issue butterfly1 Main CFD Forum 1 January 2, 2014 02:34
Question for modelling flow in porous media legendyxg FLUENT 9 April 21, 2009 22:24
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 05:52
Fluid flow in porous media question Orlando FLUENT 2 September 12, 2001 10:31
