Coefficient Cmu change
Like Tree1Likes
  • 1 Post By fluid23
Old   May 23, 2016, 14:57
Default Coefficient Cmu change
Jinsoo Park
jspark is on a distinguished road
I want to change turbulent coefficient Cmu from a constant to a function of height in star-ccm+.
Is it possible easily? Or, should I use user code?
jspark is offline   Reply With Quote
Old   May 25, 2016, 02:36
kevin alun
marmot is on a distinguished road
No you can not use an inline field function for this.
Not sure why you want to change Cmu, perhaps changing a material property is better, like visosity instead of a model parameter.
marmot is offline   Reply With Quote
Old   May 25, 2016, 12:46
Jinsoo Park
Thank you for answering.
I am studying atmospheric boundary layer.
I need to assign different value according to the height in the atmospheric boundary layer.
I know the field function can not be used for the Cmu.
But, is it impossible if the user code is used?
Old   May 25, 2016, 15:40
Matt
fluid23 is on a distinguished road
I believe marmot is correct, it does not make sense to change Cmu vs height. You should be changing other parameters... Have you by chance read over the ABL section in the help files? I think it may be of some use to you.
User Guide > Best Practices > Modeling Atmospheric Boundary Layers
What exactly are you trying to capture by varying Cmu vs altitude? That may help us understand how to approach this.
fluid23 is offline   Reply With Quote
Old   May 26, 2016, 00:48
Jinsoo Park
Recently, there are ABL researches to use Cmu vs height, in order to achieve horizontally homogeneous atmospheric boundary layer, especially in turbulent kinetic energy.
So exactly, I want to impose that
turbulent viscosity = (function of height) * Cmu * k^2 / e.
Old   May 26, 2016, 09:16
Matt
turbulent viscosity = rho * Cmu * k^2 / e so what you are proposing here is to vary density with altitude (which makes physical sense).
what you need to do is setup a user defined equation of state. I have never actually had to do this myself, but I believe the process would go something like...
1. Select User Defined EOS when setting up your physics continua (rather than Ideal Gas or whatever you had been using).
2. Define a field function that using ideal gas law and atmospheric density lapse rate equation of your choice.
3. Go to Continua > Physics > Gas > Material Properties > Density and change it from Constant to Field Function.
4. Select your field function for density vs height.
jspark likes this.
Old   May 27, 2016, 04:21
Jinsoo Park
Thank you for deliberate replies.
Changing density seems a good alternative way in my case.
I will try to use your suggestion.
However, I am afraid that I can't change density when I use Boussinesq model with buoyancy effect.
Old   May 27, 2016, 09:25
Matt
Can you even use that for a gaseous flow? I thought that model was specific to liquids. If you are dealing with atmospheric boundary layer I would stick with air.
Old   May 27, 2016, 23:13
Jinsoo Park
I have a problem in changing density.
I tried to change density property, but density was not changed in constant density option.
I can change density if I choose polynomial density option, but I have to choose energy option too and the results are abnormal.
UDF Cmu change selçuk ataş FLUENT 2 July 19, 2017 12:24
phase change with CFX aximefu CFX 5 March 28, 2012 03:38
error message cuteapathy CFX 14 March 20, 2012 06:45
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 02:33
changing Cmu value in k-e models ramesh FLUENT 0 January 1, 2004 01:48
