Report value in csv file
Like Tree2Likes
  • 1 Post By marmot
  • 1 Post By taillanm
Old   July 4, 2016, 10:09
Default Report value in csv file
taillanm is on a distinguished road
Hello all,
I have n simulations files where I want to export a report value into a csv file. I would loop first to read those sim files; My report value of the first sim file would go in the first line of my array, my value of the second sim file in the second line of the array and so on..
Do you have an idea of how it might look like?
taillanm is offline   Reply With Quote
Old   July 5, 2016, 02:27
kevin alun
marmot is on a distinguished road
I did not test it but something like this structure,
ArrayList simRuns = new ArrayList();
ArrayList name = new ArrayList();
Simulation simOld = getActiveSimulation();
//Input parameters
name.add("13A");
simRuns.add("M13A");
name.add("14A");
simRuns.add("M14A");
name.add("15A");
simRuns.add("M15A");
//Get the location of the sim file
String filePath = simOld.getSessionDir().toString();
//Close sim file
simOld.close();
//Array to store my values
ArrayList<Double> someValue = new ArrayList<Double>();
for (int i = 0; i < simRuns.size(); i++) {
String simName = (String) simRuns.get(i);
//Get my case
Simulation sim = new Simulation(filePath + File.separator + simName + ".sim");
//whatever report you need, example area average
areaAvgRep=sim.getReportManager().createReport(Are aAverageReport.class);
//you can also do a user field function but example is primitive for pressure
PrimitiveFieldFunction pFF = ((PrimitiveFieldFunction) sim.getFieldFunctionManager().getFunction("Pressur e"));
areaAvgRep.setScalar(pFF);
//Lets say you have a section already in the sim file
PlaneSection planeSection_0 = ((PlaneSection) sim.getPartManager().getObject("zSection"));
areaAvgRep.getParts().setObjects(planeSection_0);
//get the value
aValue = areaAvgReport.getValue();
someValue.add(aValue);
//close
sim.close();
} //go again for the next sim file
//Time to write out the data
FileWriter fstream;
BufferedWriter reportfile = null;
try{
fstream = new FileWriter(filePath + File.separator+"SomeValue"+".csv" );
reportfile = new BufferedWriter(fstream);
reportfile.write("caseName"+","+"ValueType");
reportfile.write("\r\n");
for loop
reportfile.write(name.get(i).toString() + "," + someValue.get(i).toString());
end loop
reportfile.close();
}catch {something here}
aow likes this.
marmot is offline   Reply With Quote
Old   July 7, 2016, 03:39
Hi thanks for the input, I finally worked on what I already had to loop over my sim files; this should work:
package macro;
import java.io.*;
import java.util.*;
import java.io.File;
import java.io.BufferedWriter;
import java.io.FileWriter;
import org.openide.util.Exceptions;
import star.common.*;
import star.base.report.*;
import star.base.neo.*;
public class exportCSV extends StarMacro {
public class SimFileFilter implements FilenameFilter {
public boolean accept(File dir, String name) {
return name.endsWith(".sim");
public void execute() {
Simulation sim = getActiveSimulation();
sim.kill();
File simDir = new File(resolvePath("."));
System.out.println("Directory: " + simDir);
for (File f : simDir.listFiles(new SimFileFilter())) {
startAndRun(f);
public void startAndRun(File f) {
String fileName = f.getAbsolutePath();
Simulation sim = new Simulation(fileName);
File file = new File(resolvePath("/home/m1tailla/TAILLANDIER/Etude/test/output.csv"));
Collection<Report> reps = sim.getReportManager().getObjects();
try {
BufferedWriter out = new BufferedWriter(new FileWriter(file));
out.append("ReportValue");
out.newLine();
for(Report ri :reps) {
// this is specific for my case, if you have many reports but are interested in only specific types (here volume average) it should look like this:
if(ri instanceof VolumeAverageReport){
VolumeAverageReport vr = (VolumeAverageReport) ri;
out.append("" + vr.getValue());
out.newLine();
out.close();
} catch(IOException ex) {
sim.println("Error type: " +ex.getMessage());
sim.saveState(fileName);
sim.kill();
aow likes this.
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
