Flow analysis in between two discs (tesla Turbine)
Old   October 18, 2016, 16:40
Default Flow analysis in between two discs (tesla Turbine)
Saima
Saima is an unknown quantity at this point
Hello All,
I am using Star CCM+ to analyse the flow in between two co-rotating disc.
I have defined inner radii as an input, outer radii output. Impose Total pressure and static pressure boundary conditions.
If need to define dimensionless mass flow rate at inlet, what is the possibility to do that?
How do i calculate the efficiency? Would it be based on inlet and outlet radii?
Thank you
Best Redards,
Saima
Saima is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Flow driven of darrius turbine using ANSYS cfx TKP CFX 3 April 9, 2015 04:38
Tutorial related to flow analysis of Hydro turbine Sanjay Jain FLUENT 0 April 29, 2008 14:33
Re: how to do this turbine blade passage flow nanl manish Fidelity CFD 1 November 2, 2006 23:01
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
