Negative moment while simulating wind turbine
Old   October 19, 2016, 06:59
Default Negative moment while simulating wind turbine
Angelika
angawi is on a distinguished road
Hi everyone,
I'm simulating rotating wind turbine and my aim is to find maximum power.
Specification:
-rated power 6,150 kW,
-rated wind speed (inlet) 14 m/s,
-rated rotor speed 12,1 rpm (rigid body motion).
I'm getting good thrust value (about 4300 kN), but torque value is negative (about -30 MNm) what is non acceptable, it should be about 5 MNm.
I have tried many things (refine mesh, size domain etc).
I think the problem may lie in wrong defining moment report.
What should be my coordinate system for moment report? Local coordinate system which I have placed in the center of rotating plane?
Please help me.
angawi is offline   Reply With Quote
Old   October 19, 2016, 09:08
Matt
fluid23 is on a distinguished road
What does your residual plot look like?
fluid23 is offline   Reply With Quote
Old   October 19, 2016, 09:24
Angelika
The first one with k-epsilon turbulence model, second with k-omega SST.
On the second one, there is a change in values of residuals in 5s (one rotation). And the second one simulation has no tower, only rotor.
Old   October 19, 2016, 09:26
Matt
Why are you plotting residuals against physical time?
Can you share a screen shot of your physics continua?
Old   October 19, 2016, 09:33
Angelika
This is how it looks like. I have 5 mln cells in rotating region and 1,8 mln in stationary region.
Time step 0,013(8) s, because 12 rpm, so takes 5 s to complete one full revolution. 5s/360 deg = 0,013(8) s.
Don't know where is the problem, I'm beginner with cfd..
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 10:11
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
