Film Cooling in a Combustion Chamber
Old   January 10, 2017, 07:56
Default Film Cooling in a Combustion Chamber
egkw34 is on a distinguished road
Dear all,
I am trying to model fluid film cooling in a combustion chamber. I have used the fluid film model with evaporation in Star-CCM+. However, when looking at the results of the simulation, there is no drastic change in the film density to show that it has changed to a gas, despite the film temperature having exceeded boiling point.
Is there a set of models that can consider this, so as to provide a better indication of the film temperature and heat transfer downstream of where film evaporation has supposedly taken place?
egkw34 is offline   Reply With Quote
Old   January 20, 2017, 01:35
me3840 is on a distinguished road
I'm not sure it's density you want to be looking at. The wall film will only hold the condensed phase, so it's density should mostly be constant. You want to look at the film thickness.
me3840 is offline   Reply With Quote
Old   January 20, 2017, 08:44
I wanted to look at density because of the mixing with the combustion flow, i wanted to see if the fluid film would be overcomed from the combustion flow and the temperature at the wall.
When i did the simulation i assumed that the model would capture that aspect as well, but it did not.
Old   January 20, 2017, 09:48
I would take a look at the fluid film model's theory in the user guide. You're assuming things it doesn't do. It is not capable of 'mixing' of any sort, the film model only models the film. If some process happens to remove mass from it, then that's the last thing it sees. Any mixing would happen outside the fluid film.
I'm not sure what you mean by overcome, though.
Old   January 23, 2017, 06:36
Could you please view the two attached images? I think it will better clarify one of the issues
Old   January 23, 2017, 14:55
Is there any volume fraction of the methanol vapor in the main domain at all? You are suggesting none of it is evaporating, let's see if that's true.
Old   January 26, 2017, 05:59
You were right! Thank you!
boundary condition at the outlet of a gas turbine combustion chamber sharifi FLUENT 1 November 14, 2012 10:57
Particles affecting radiation in combustion chamber bharath CFX 0 September 23, 2011 21:41
Unbelievably high velocity magnitudes in film cooling - HELP! shankara.2 FLUENT 0 June 1, 2009 22:43
Coal particles in combustion chamber Luis Filipe Fabiani CFX 2 March 10, 2009 15:37
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
