January 23, 2017, 14:29 |
solution crashed after 5000 inetrations
Saima
Rep Power: 16 |
Hello All,
Analyzing co-rotating disc compressible turbulent flow. Solution suddenly crashed, kindly see attached mesh and residual history. Kindly suggest what could be the reason.
Best Redards, Saima |
January 23, 2017, 14:45 |
Rep Power: 24 |
I don't really know what your geometry looks like, can you provide more images?
That mesh looks like it has some problems though. Only two cells in that gap and a lot of collapsed prisms on that small feature. |
January 23, 2017, 15:01 |
Saima
Rep Power: 16 |
kindly see attached
January 23, 2017, 15:04 |
Rep Power: 24 |
Yeah, your mesh doesn't look adequate for this. You should refine that gap, improve the prism mesh, and add more cells between the plates. The thin mesher would be a good choice here. Alternatively since you have an easy geometry you could do a directed mesh, which would be very efficient.
January 23, 2017, 15:18 |
#5 | |
Saima
Rep Power: 16 |
January 23, 2017, 15:23 |
Rep Power: 24 |
January 23, 2017, 18:39 |
#7 | |
Saima
Rep Power: 16 |
As you can see the middle part is large in thickness, I have seen tutorial of a pipe three component but its same thickness. https://steve.cd-adapco.com/articles...-boundary-mesh How do I managed the middle one. If i am following steps its saying on second step, error is attached.
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 15:45 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 12:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
