January 23, 2017, 14:55 |
Basic model selection question
Marco Bianchini
Rep Power: 9 |
I am switching from the k-epsilon to the k-w model, do I have to delete my solution and start again or can I keep my convergence and just click run? How do I know which model is using? thank you |
January 23, 2017, 14:56 |
Rep Power: 24 |
No, you can just keep your run and keep going. You may have to change your turbulence BCs depending on how you specified them.
You will see in the text window which equations are being solved. |
January 23, 2017, 15:00 |
#3 | |
Marco Bianchini
Rep Power: 9 |
What about if I change BCs while it is running? Do they get updated or do I have to stop, change them, initialize and run? |
January 23, 2017, 15:01 |
Rep Power: 24 |
If you change them while running they will be updated automatically.
January 23, 2017, 15:14 |
#5 | |
Marco Bianchini
Rep Power: 9 |
I am a bit worried because it keep sayings tke and sdr, as it was doing with the k-epsilon. Is it ok? |
January 23, 2017, 18:47 |
Rep Power: 24 |
If you were running k-epsilon before it should have stated TDR instead of SDR.
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
STARCCM+ Model Selection Question | s1300044 | STAR-CCM+ | 5 | August 10, 2013 05:32 |
second and final question about flamelet combustion model | AdidaKK | CFX | 0 | October 17, 2009 07:25 |
