February 1, 2017, 05:17 |
Reversed Flow
walter
Hi dear,
I'm working in a simulation with Star CCM+; I have a centrifugal fan cooling an electronic board and a heat sink with two different "pressure outlet". I have a problem, because the iteration say me "reversed flow on inlet and outlet". So, I would know if there is some problem on simulation setting or the the turbolence effect the flow direction. N.B. I read a lot of post and I tried to extrude the outlet ducts, I tried refinement mesh, I tried "flow split outle" instead "pressure outlet" but he results are the same. I attached an image with the velocity vector field on section plane Thank's all. |
February 8, 2017, 09:47 |
Ping
Rep Power: 20 |
looks like you need to extrude much further to prevent the reverse flow - they can be progressively much bigger cells by using the extruder carefully and the warning is not related to turbulence but is due to recirculation
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] | NormalVector | ANSYS | 1 | May 15, 2012 23:50 |
Reversed Flow for a tenth slice of a rotor | neptunemmx | FLUENT | 10 | January 30, 2012 13:51 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
reversed flow | Sastry | FLUENT | 5 | March 22, 2007 08:05 |
