February 6, 2017, 05:43 |
large mesh deformation problem
mike
Rep Power: 14 |
Dear all;
I am going to study a moving boundary fluid mechanic problem using star ccm+10 for my M.S thesis. The problem is a kind of dynamic mesh in which the motion of the surface is known as grid velocity. Considering the initial height of the region by 4cm , after severe compression of fluid zone, the final height will be around 4 mm. I want to know is it possible to simulate such a large mesh deformation problem in star ccm without getting negative volume? How? (using morphing mesh?) Does Star CCm have remeshing option for highly skewed cells in the region or not? Thanks for your replies. |
February 7, 2017, 15:31 |
Rep Power: 10 |
As always, it depends on the exact problem. Compressing a simple cylinder by a ratio of 10 shouldn't be a problem. But if the setup is more complex it can be more difficult.
You can try the morpher of course. For a relatively simple compression with known grid velocity you can also try User Defined Vertex Motion. This will use your applied motion distribution not only on the boundary but also on the internal vertices. There is no automatic remeshing capability, s. How to remesh or realign the mesh in transient analysis |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Problem with rotational mesh deformation | NymphadoraTonks | CFX | 1 | October 17, 2004 18:43 |
