February 8, 2017, 08:29 |
Issue Importing NASTRAN file to STAR CCM+
Eve
Hi guys,
I am currently at university working on a CFD project and am teaching myself how to use CFD packages. I began with ANSYS Fluent and now need to change to STAR CCM+ for simulation/solving. However, I wanted to use my mesh file from ANSYS as I don't want to spend time redoing work I've already accomplished and going back to square 1. So, I've exported my mesh file as .nas and loaded it into STAR... So, my issue- my model is an electric motor where I am investigating the air flow, so the free space between rotor and stator. In ANSYS I've defined the "free space" as a fluid so it differentiates it from the solids. However, when importing into STAR it's treating the domain, rotor, stator & free space as one part/ a single geometry in the geometry tree, so I am unable to select the fluid region to provide any information and define the rotor/stator as solids. I am (possibly incorrectly) assuming this is due to the type of format of a .nas file, however it's the only format I can export from ANSYS and import into STAR. I have no knowledge of STAR and I have so far only learnt how to split by patch however this option is grey-ed out. I will continue messing around with it myself, but am hoping someone knows if there's a quick way to get around this solution (export as different file type?) as otherwise I'm going to have to go back to step one and repeat all the work I've done so far in ANSYS, which for obvious reasons I'd rather not have to do. I've tried searching for this issue but mostly it's just people having importing issues rather than issues with the model once imported or else going the other way of importing a STAR mesh to Fluent. Thanks in advance |
February 8, 2017, 10:06 |
Ping
Rep Power: 20 |
i would suggest other options like star can import fluent volume mesh directly as grd or cas or msh formats and these work well otherwise get the cad exported in step or iges format and this is better since the mesh you create in star will be better and more suited to the star solver
February 9, 2017, 07:15 |
#3 | |
Eve
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
