Ice Layer Thickness Value does not change although Temperature changes on a surface |
April 3, 2017, 08:13 |
Rep Power: 9 |
Hello everyone.
I am trying to simulate the defrosting of a car's windscreen but I am facing troubles. For some reason, the ice layer thickness valeu does not decrease on my windscreen. However, the temperature gradually rises over the whole time. Before I simulated the defrosting, I simulated the flow inside the passenger compartment only solving for segregatee flow and K-Epsilon Turbulence until convergence. After that, I switched within the physics continuum to implicit unsteady, activated a 0.5 mm ice layer on the windscreen and froze everything except energy and DeIcing. When I simulate it, the temperature changes, but not the ice layer (same surface). Thanks for your help in advance. |
April 5, 2017, 05:52 |
Rep Power: 9 |
Never mind.
After trying many different things I managed to fix the problem. It had to do with the stopping criteria for maximum inner iterations. Now the ice layer updates every 5 iterations Sent from my iPhone using CFD Online Forum mobile app Last edited by Dehyp; April 5, 2017 at 06:56. |
April 5, 2017, 08:20 |
Nils Hennig
Rep Power: 11 |
Maybe it was only the update Intervall for your scalar-scene?
deicing, ice melting, temperature, unsteady, windscreen |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) | Irish09 | OpenFOAM Meshing & Mesh Conversion | 23 | July 15, 2013 07:45 |
[snappyHexMesh] Effect of adding layers with sHM | Nucleophobe | OpenFOAM Meshing & Mesh Conversion | 4 | August 20, 2012 16:45 |
[snappyHexMesh] Problem with snappyHex: no body | lovecraft22 | OpenFOAM Meshing & Mesh Conversion | 5 | June 23, 2010 11:05 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
